Guys, I finally received my recommended GL4 fluid for my 73 TR6. Prob. is, my gearbox does have a leak, and I had been topping it up with GL5. My Bentley manual says not to drain the gearbox, only to top it up. (Why is that?) Anyone see a prob. w/draining it, so that I'm able to fill it up with the recommended GL4? Or should I just top it up w/the GL4. in which case there would be a mixture of GL4 and 5. Also, which GL to use on the rear axle, 4 or 5? As always, your help is appreciated.
