I have a CD with several hundred pages of tech info. Each page of tech info is a pdf file, image only (not text).
Problem is that the only way to access each pdf file is by using a ten year old flash menu. Otherwise, you have to drill down into the folders and "guess" what the file is by a numeric filename.
Here's what I want to do:
Look "inside" the .swf flash file itself, and see how the files are referenced. I want to make a simple html menu to all the files.
Maybe there's an app to simply "open" the swf file and "export" the tree to text or html?
Any suggestions?
Thanks.
Tom
Any suggestions?
Thanks.
Tom
Hi Guest!
