I certainly would not suggest bending the control arms unless you have a great deal of knowledge about strength of materials, heat treating & such. The control arms are originally heat treated to a certain combination of ductility & strength. This part is too critical to just heat & bend.
You CAN create negative camber by using shorter upper arms as found on certain other car models with the same type shock.
