Trying to figure out the right way to connect a relay to my adjustable thermostat for my electrical fan. Current set-up: Two wires from the fan; one to ground, one to adj. therm. One wire to adj. therm. from fuse box. The relay has #86 for (Switching Means), #85 for (Ground), #30/51 (Fused Power), and 2 #87's for lamps, etc. What is the proper way to connect this all together? Do I need to use #85 if the fan is currently grounded? Or even is using a relay for my fan even necessary if I already have the power fused?
Any help is appreciated.
Thanks
Thanks
