jlaird
Ok, all stop.
Back to square one. Have returned all carb specs to stock.
Nothing seemed to work properly.
Found a bit of an air leak but only 2 or 300 RPM change when useing carb cleaner, that's not it.
I know the book says 1/8 inch measurement on carb float but what is is for an H1 it sure isn't 1/8th. Heck my floats are brass and I have small arms. It seems that the fuel level is high to me. Shoot it just runs into the carbs.
Needle and seat in the float chamber have the same stock number so that's not a prob.
Anyone have an old H1 manual and can check the float lever spec ie what to set it at for me? An orginal Bugeye book should also say. <span style="color: #FF0000">7/16</span> just found it.
