Good advise Tom. Jim, what can I say. How much equipment do you have? I do this kind of repair a little different than most. Sand very lightly with a folded 400 grit wet and dry paper in the crack and chip, getting a small bit of scratching on the paint. Now tape to within a 1/8 inch of each. Clean and tack, paint (spray if possible) until over filled. Pull the tape and let it set for a couple of days. Sand with 2000 grit wet and dry, lots of soap in the water until flat. Buff it out. Be sure and cover the rest of the car and any others in the area park them away.
Lots of auto paint stores can mix you a spray can of the right color, if you take the car by and let them shot it, or mix your own and get one of the HF touch up guns and mix your own.
Wayne
