G
Brosky, first I love your engine! But be careful about using braided hoses in an area where there is <span style="text-decoration: underline">any</span> contact with other components, especially electricals. These things, as you well know, will cut through other any sheathing or hose they contact when there is any vibration or movement. I notice your rear coolant hoses are covered with SS braided sheaths and the movement of the engine will make for constant sawing effects on the wiring bundle in this area. Ask me how I know this. Heck, I'll tell you. My braided slave cylinder hose cut into a rubber drain hose coming off my oil separator. My braided oil cooler hoses cut into the wiring for my fan, until I re-routed the hoses and secured them. These same braided oil lines cut into, well, me when it had a few wires come undone.
Again, just constructive criticism.
You've set an example for us all.
