kennypinkerton
I have attemped (first time so don't cut me down too bad) to put vinyl on the headliner of my wife's car. It was relatively cheap vinyl (maybe that had something to do with it) from walmart. about $4-5 a yard. I couldn't pass it up. So I bought some "very good" adhesive, hoping it wouldn't fail in the heat we have here.
After I removed and cleaned the dry-rotted foam from the (heavy foam) molded headliner, I sprayed it down with 3M - Super Trim Adhesive. Then I layed out my vinyl, and sprayed it too. I spent about 1/2 hour getting all the wrinkles out, and then set it in the middle of the living room to set-up.
About 1 hour after I set it there, I went over to look at it. Ahhhhhhhh!!! The adhesive had attacked the vinyl and left little blisters in the same pattern I had sprayed on the backing. Looked horrible IMHO.
Thing is, this was intended to be the biggest gift my wife would recieve from me for christmas. As almost all of her cars (since we've been together anyway) have had sagging cloth headliners. Well she came home and saw it (she knew I was doing this for her), and she thought it looked great, but I disagree.
Just a warning to everyone else though (and it says so on the can in very small letters - hindsight 20/20)...
Read the whole can!!!! Also 3M Super Trim Adhesive will blister Vinyl!!!
Hi Guest!
