TR2/3/3A A-type OD operating valve copper washer
Jim_Stevens
Hi, all--
Does anyone have a source for the copper washer that goes under the cap to the operating valve (Moss 324-950)? All the 1/2" copper washers at the local hardware stores have too wide an OD and won't fit into the OD housing. Trying to get the temporary pressure gage to seal. Thanks-- Jim
Moss UK does have them listed, btw, so all is not lost.
TRF has them listed as well, 500568. The kit of copper washers I got from HF has a size that is close, but you'd have to open up the inside diameter a bit, with a Dremel or similar.
Jim-If you know someone with a lathe, it is any easy job to slip the washer on a bolt&nut and turn down the OD.
Berry
