AweMan
For those of us whom occasionally use heat for various projects.
Many bolts, nuts and washers are coated with cadmium, Cadmium is a carcinogenic! {cancer causing agent}
We MUST take extreme caution when using any type of heat source on bolts, nuts and washers in the process of working on our cars and other home projects.
If heating a bolt,nut or washer is a must do situation, make absolutely sure you are up wind {and I mean literally} Use a fan to blow the fumes away from you and or anyone in the immediate area. DO NOT heat cadmium coated items in ANY enclosed area!
Cadmium coating comes in several different colors, the three most common for bolts, nuts and washers are black, silver and gold,
Sanding or grinding cadmium coatings off is NOT an option! At the molecular level it still remains in the pores of the parent metal. The grinding/sanding process produces cadmium dust that is just as if not more dangerous than the fumes themselves.
We all know how dangerous lead fumes are ..... cadmium is WORSE!
Thank you for your attention and may we all live long prosperous lives!
