In the past you said that you had put an early Spit cam with bearings in your racing 1500 Spit. Do you think this swap could be done with the engine in the car.
I have neither a lift nor a lot of space to work in.
Morris, the engine must be removed to install the cam bearings.
You may be able to do just the cam swap with the engine in, but I wouldn't want to try it.
Jeff
