Baz
...has been the source of my 12 months of SU problems.
A 1" piece of rubber that goes from the floatbowl overflow into that pipe that runs to the charcoal canister.
Over the years I guess the rubber had deteriorated to the point where it formed a blockage.
I pushed it through with a screwdriver last night.
It's a different car.
The symptom was always idling well, after a few minutes (when the float bowls ran dry, unable to vent) it would splutter and die.
After everything I've done to these carbs, bad and good, it was never their fault. What a relief.
If you have the pipe that runs from front carb to rear to canister, check em out or replace the rubber.
