Some progress has been made on my little bugeye. Pictures will be posted hopefully in the near future.
In between work, holidays and other commitments I have gotten the following done in the last three months or so:
- Reinstalled the carbs after having Hap rebuild them
- Re-sleeved my master cylinder to 3/4" to better match my disc brake change.
- Swapped the rear brakes for the later style
- Bled the brakes and clutch (again)
- Fired the sucker up and re-checked timing, balanced carbs, etc. - The idle is about at 1,000 RPM with timing at about 8 degree BTD.
She runs well and pulls great in my short jaunts up and down my driveway. Yippee!!
My problem is a minor hard start issue (much better than it was before the carbs were re-built) and a run on\diesling problem at shut down. Yikes! I assume this can cause damage and want to figure out what's happening. This is a fresh rebuild by an amateur mechanic (i.e - me) When it is running, it runs very well and smooth. It revs fine.
Any thoughts on the run problem?
Thanks!
Thanks!
