a little help with my turn signals
alegre
Hi! I have a 72 mg midget that I rewired using the wiring harness of a 69 or so mg midget. Everything works on the car except my turn signals I cant get them to flash, any suggestions?
It's a general question and one you'd probably get accurate responses to here, but I suggest you try posting this in the "spridgets" area...
Welcome to the forum! I had the same problem and I figured out that the wires ran through the Hazzard switch the is located at the console. I would suggest looking at the wiring diagram in bentley and trace where they should go. I thnik the 69 is the same but there may have been a slight difference that is throwing you off.
