Patton
Hi guys,
I am doing all of the prep work for pulling my engine this week. The plan is to have everything stripped that I need to have off this weekend. I will pull the engine as soon as I can find help for the couple of hours to unbolt and guide it out. The paint shop will be ready in a couple of weeks, so I am getting into crunch time.
Can I use the rocker cover bolts to pull the engine, or do I need to remove the rocker? (while out I am not doing any work to the motor)
Also, what should I use for lifting brackets? On the Sprite I used a couple of big washers and bolted straight to the chain but the weights are much greater here.
Does anyone have the exact dimensions of the placement and size of the hole for the dual washer jet for Longbridge BN4's?
Thanks
Patton
[ 01-24-2004: Message edited by: Patton ]
[ 01-24-2004: Message edited by: Patton ]</p>
Thanks
Patton
