first, I posted before about the random misfire. I took the Pertronix module out and re-installed it. That seemed to help. I might have been a bad ground????
The car still idles a little rough. A local mechanic said it sounded like the carburetors. He tried adjusting the only adjustment on the carbs. I told him that that was not the air/fuel mixture. The adjustment didn't help or hurt. When we were revving the engine a little to listen for anything wrong the engine seemed to stall like it was starving for fuel. I brought it home and left it sitting while I did some chores and when I started it again it ran fine. I did balance the carbs while I was at it.
While at idle I lifted the pistons on each carb. When I did this to the rear carb it stalled the engine. When I did it to the front carb the rpm's dropped a little. This tells me that the mixture is lean. The only problem is that the Stromberg 175's don't have a mixture adjustment. Does this mean that I am going to have to buy new carberators? I did rebuild the carbs before I got the car back on the road.
Next question. Can the lever shocks be effectively? Where can I find kits to do this?
Last question. My car had the tube shock conversion when I bought it but the ride was way to hard. Almost like not having any suspension at all. What shock do you guys with the conversion use?
Thanks, Pete
Thanks, Pete
