A/C refrigerant pressure
BritCarFan
Does anybody know the required pressure of the A/C system on my '93 XJ40?
The pressures are dependant on outside temp, refrigerant charge, idle speed etc.I would expect 30 to 40 psi on the low side, and 180 to 220 or so on the high side. What do you get??
I hooked up the pressure gauge to the low side and with the engine idling and the A/C at max I was reading 45 psi. According to the gauge that is right at the maximum for the system.
That seems high. Are the fans working? If so, I would suspect a bit of an overcharge. It would be helpful to know the high side pressure also.
Which refrigerant is in the car. R134 runs at a little higher pressure than R12.
It has the R134 refrigerant.
Ok...I know I'll open a can of worms on this comment...but I've read and heard over and over how tough recharging AC systems can be....both my 2002 SUV and my 91 Benz were blowing hot...I went out, bought a $33 recharge kit from Walmart (it came with 3 cans of R134a)....put 1 1/2 cans in both vehicles on the low side until the gauge read in the blue area....and they're both blowing ice now....maybe I got lucky but the effort took 30 minutes total and saved me $100's in service fees....
Jesse is right, the pressures depend on the outside temp. R134 runs t highe prssures than R12.
Your low pressure reading seems OK. I would think that the high side is a few pounds low.
Does your car have a sight glass? Any bubbles in it? If so, add refrigerant until the bubbles disappear. R134 systems are more sensitive to low presures than R12.
