Morris
Problem: wildly fluctuating engine vaccum freaking out my ecu and causing poor performance.
Attempted solutions:
1) Thorougly checked for vaccum leaks using the "spray" method. Replaced manifold gasket. Disassembled and inspected carb/throttle body. (my efi system uses the ZS150 as a throttle body).
2) Replaced weak ignition system. Replaced platinum plugs with copper cores.
3) Removed and inspected head. Replaced two galled valves and guides. Checked valved clearances several times.
4) Compression check (front to back): 130; 130; 129; 140. This was pretty much the score before the problem arose. I believe #4 is getting a little extra oil resulting in a higher number.
5) Checked accuracy of MAP sensor.
So is it time to pull the cam? Could I have flatted my lobes with my sticking valves?
Another option is to insert a small fuel filter in the MAP sensor vaccum line. This will smooth out the vaccum signal for the ECU, but will not treat the source of the problem.
I am so frustrated, I am ready to drive this beast into the ground before I send it to the crusher.
