Ed_K
All of my turn signals and brake lights work. The dashboard turn signal indicators don't work. I have ohmed out the bulbs, the wires back to the terminal screws on the relay, the common wire back to the flasher, I replaced the flasher with an aftermarket, I took the relay cover off and burnished and aligned all of the contact points, still no dash indicators lights.
I noticed that when the left turn signal is flashing, if I touch the light socket case to ground the left indicator light starts working. I could not get the right indicator to work doing the same thing.
Perhaps the relative resistance of the turn signal lights and relay points are MUCH lower than the resistance of the indicator bulbs/wiring ??? Eventually
I will figure it out after I spend enough time/effort, but since I consumed most of the day troubleshooting this without any success has anyone seen this and what did you do to fix it ? Thanks for any ideas
