'97 Miata - Need to Replace the EGR valve - recommendations?
AngliaGT
I picked one up at O'Reilly's ($181!) and I noticed that it was "MADE IN CHINA".
I don't have much confidence in putting that on my car,& decided that even if I have
to spend a lot more money that it might be worth it in the long run.
Any suggestions on where to buy/best quality?
You might also check out the Standard Auto Part EGR valve, EGV467. It's much cheaper than the Wells, and I believe they are made in Canada or Mexico.
Doug, in addition to cleaning it or replacing it, you can also delete it. It may hurt your gas mileage a little, but you won't be getting carbon build up in your intake, and your head should be a lot cleaner as well.
