Bremer
Most people seem to discourage the use of the 92mm pistons and liners due to the difficulty and accuracy required to machine the block. However, inquiring minds need to know if there are any board members here that could share first hand experience of such an engine build. Was it difficult (i.e. expensive) to get the machine work done? If yes, what were the issues? Which pistons and liners did you use? Are there any effects that diminish usability for a road car (leaks, overheating, others)? What other modifications have you done to support the larger displacement, and finally how does the engine feel?
Thanks!
Thanks!
