Michael J.
Well, Finally got running following engine rebuild, and a host of problems that never seemed to end. Finally got things sorted out, or so I thought.
Was driving the car. This car has a Keisler 5 Speed Conversion. Occasional rough running and almost cutting out followed by smooth. Roughness seemed to be at 200- - 2500 rpm. I was attributing this to a half a tank of seven month old gas. Added water absorber, injector cleaner and another half tank of gas. Still occasionaly rough with low power, but less often. Gas seemed to be it.
Suddenly almost shut down when reved to about 4,000 RPM. Limped home at idle. Now car idles smooth, although at about 1100 rpm (was that high before the problem), but when the throttle is opened even a little, runs rough and rpm surges up and down almost 2000 RPM. Take your foot off the gas and it idles smooth.
I looked for disconnected vacuum lines. I did not see anything disconnected in the underhood wiring.
I have no idea where to look next. Any ideas? I need help!
Thanks
Thanks
