David Palmer
I have a 1979 MGB with a Weber 32/36 DGEV carburetor, a Lucas 45DE distributor, and an 18V883 model engine. The trouble started a few months ago after I had the gas tank filled, and ran the car for a few minutes. It ran just like it always had, then suddenly cut out on me, and I could not get it to restart. I recently removed, cleaned and reinstalled both the carburetor and the distributor, reset the timing, and am still unable to get the car to start. The starter will crank the engine, but it will not fire. I am getting a current to the distributor cap (which I discovered the hard way), but I do not appear to be getting a spark on any of the spark plugs. The distributor cap appears to be clean, and all of the connections seem to be OK. Is there something simple I may be overlooking, or do I need to look into replacing the distributor or something even more serious?
David
David
Hi Guest!
