caseyjones955
Member
Good day all. I have a 79 Midget w/the stock Stromberg carb and distributor.
I have checked compression, adjusted the valves and set timing in many places (now at 8btc) it runs well above 2200 rpm, before that point it appears to miss on one cyl. After checking plugs it appears to be #2, its slightly gray where the rest appear almost new.
Lumpy idle and runs like a bunk cyl, vibration becomes really pronounced between 1500-2200 rpm, above 2200-ish it smoothes out and gets responsive again. Its very smooth and happy at speed. I had a british car guy once over it and he speculated it was an electronic problem. Im still hunting it down. Please help, this just became my daily driver. Any other checks or common culprits?
Thank you
Tony
Thank you
Tony
