MGB 77 MGB Sway Bar Size
kyreb1862
I recently ordered a new set of sway bar bushings to go with my suspension bushings. The bushings I ordered from Moss will not fit my sway bar. What size is the front sway bar on a 77MGB and where can I get a set of bushings that will fit it?
Kindest Regards
John
John - you should have a 5/8" bar & bushing # 021-767 should fit it...if that's the number you orderede & it doesn't fit, somebody's replaced your bar with either an earlier 9/16" or an aftermarket one.
