kyreb1862
My 77 MGB has developed a cooling problem. The first radiator fan switch failed in the closed position causing the fans to run constantly. I then ordered a new fan switch and installed it. Now this switch doesn't seem to want to kick the fans on. The hook up and installation seemed to be pretty straight forward but the new swicth is not working. There is power up to the swich but, even after the engine reachs a temp which should cause the switch to operate,no power goes through it to the green/black wire going to the fans. I used a jumper and connected to the green/black wire and one of the fans kicked on. I think the other fan motor is bad. Does anyone know anything I can do to make the switch work? Or is this just something I'm going to have to return and wait for a new one?
Regards John
Regards John
