Don_Houston
I have stripped the set screw while attempting to replace the metering needle on the air valve. I have not tried to drill and extract that tiny screw for fear of ruining the valve. I cleaned the the needle and reinstalled, seem to be running ok. I successfully replaced the needle on the second carb.
Where can I buy a replacement air valve in case I ruin the air valve if/when I try to drill the screw out? Many thanks.
