7
76midge
hi, my 1976 midget has an electrical problem. it sat and the battery was dead. i put on the charger, and got the car started, turned off the charger and let it run for 10 minuites. well long enough to charge the battery, and get it warmed up. however, when i cut off the car, and put it into first gear (clutch is rusted to fly wheel) to start in first gear, the only thing i got was the indicator light barely lighting up to indicate the fuel pump was working. it would not even turn at all. so, the only possible things i know of are;
1. the alternator is bad, and if this is so, i can restart the car and let it run longer. since the alternator would not be charging the battery, the car would run the battery all the way down and the car would stop on its own...or someone could teach me how to do a continuity test on it.
2. there is a short somewhere in the system...in which case, im screwed.
3. could be a bad battery that wont hold enough charge.
that is about all i know on it. any help would be great. some other problems it has are; bad brakes, rust, clutch, and the pipe that goes into the gas tank it above the bottom of the tank, so when it gets down to 3 or 4 gallons left in the tank, it can get anymore gas.
thanks for any input...
Jason
Jason
Hi Guest!
