Flatlander
I am looking at purchasing a 74 Midget. It is located at 9000 feet in the Rockies. It drives well, idles great and is a good solid car. The problem is that in accelerating it reaches about 2500-2800 rpm then flatlines and cannot accelerate any higher. Car does not miss or exhibit any sputtering. The owner in trying to solve the problem installed a Petronix ignition system thinking it was an ignition problem but with no solution. If I purchase I will be driving out of the mountains and will have to go up several steep grades. My questions are:
1. Any ideas as to cause?
2. Will problem go away the lower in altitude I get?
3. Would this be a symptom of a larger problem?
Thanks
Thanks
