I have my engine out for other reasons and am considering a bit of exhaust port work as recommended on the British Automotive site. I need to research exactly what to do, but I was wondering if it is worth the effort, and if it is advisable to skim the head a bit for a minor compression ratio increase.
It seems fairly obvious to remove the little tubes that stick into the ports for the air injection, and maybe just clean the ports up a bit. Would a high quality valve job be noticeable in term of flow increase? As far as I know, engine is totally stock, but I'm not sure about any earlier rebuild efforts until I measure stuff.
Thanks-
Thanks-
