TR6 73 TR6 Alternator
T
TRDejaVu
A friend of mine has a problem with his charging system. As it has one of those dang-fangled alternatee thingy's (compared to my state-of-the-art generator), I need to ask advice.
Disclaimer. I am working from his description as I haven't seen the problem for myself yet. I am also assuming (yeah I know) that it's a stock alternator.
So he says that it charges OK until he puts the lights on and then the lights dim, even at higher revs.
- would that be the regulator?
- is it internal on that year's alternator?
- if yes to both of the above, can it be replaced, or do you have to change out the whole alternator?
It could be the regulator, or the stator or the winding. Cheaper to go this route and get higher amperage.
Fiesta Alternator Swap
This is assuming that his battery is in good condition??
More likely a bum diode, IMO.
Regulator is inside the alternator; can be replaced separately. But I sure wouldn't change it without having more evidence it is bad.
The Bosch swap is great for simplicity and more power/reliability; but personally I don't like that quick connect on the alternator output. I've seen too many of them burn up. So I'd be tempted to look for something with a bolted connection, like the Delco.
Actually, whether or not you like them, Auto Zone carries a really decently made alternator under their own label that they sell as a new unit. Basically this is the equivalent to the Delco 7127 unit. Quite easy to install. Well, not really easy. You will have to fabricate an alternator bracket, but everyone seems to use the standard chromed aftermarket bracket that seems to be available at all auto stores. Needs to be shaved and shortened a bit, but works great. Too, the mounting needs to be modified by cutting, but not that big a deal. Ok, ok, so it is not a drop-in lite the Bosch unit, but it does put out right about 70 amps and is well made. How do I know this? It brought the one I have to a quality alternator and starter shop and asked them to check it out. They said it was as well made as any they service. Good to know. Oh, it it does have a very hearty bolt-on for the output wire, which I upgraded to a very heavy gauge and covered with the boot from a Chevy alternator for protection and clean install.
