I am finally getting to removing the shaft to replace the rear UJ and I cannot tell if there is a front UJ access panel. I remember what a pain it is to line up the gearbox splines with the shaft from replacing the clutch. There is a small pocket about the right size to fit a screwdriver in, but this does not cause any movement. Is there a way to get to the front UJ flange?
