73 Midget Transmission stuck in first gear
jbowlby
Help! Our 73 Midget is stuck in first gear. We hae tried rocking it back and forth ect....Before I pull the %$*(!@^ engine again...anybody have some advise?
YES! jack it up and have someone work the shifter while you rock the raised tire back and forth. I have seen this work on several types of LBC with the A series. Then dont put it back in first or reverse or it might stay there again. Drive it in second until you can pull the transmission and check it out. You have to do this to find the problem, sorry.
mine stuck in reverse once, i reved the engine for a while and cussed and it came loose....
mine usually it sticks in neutral and i have to wiggle the shifter while i give it some gas....
i have my gearbox out right now, but i dont think ive fixed it yet..whatta pain........zimmmmy
This happened to me last fall.
I pumped the clutch numerous times, swore at it, and only used 2nd & 4th.
I drained the (transmission) oil, replaced it and it was fine.
Not happy with the result, I'm pulling the tran right now as it's obviously not right.
I figured a bad synchro shard (there was brass fillings in the oil) got caught somewhere and it loosened up with some violent movement.
Jbowlby,
It's going to have to come out no doubt about that. But a way you will be able to un-stick it is to drain the oil in the gearbox and remover the side cover (careful with the springs and detents). Once you have the side open you will be able to lever the shift fork back with a good size screwdriver or flat bar. You will be able to tell the fork that's giving you the trouble by having someone try and shift it. It will "pop" back out of gear so easy that you'll be tempted to "try it again in first once everything is buttoned back up. So you will get to do it all again if you do. You’re looking at too much play in either the shift fork and or the slider assembly for first. There is too much clearance and the detents are coming out to far. That’s not the only thing but what it’s likely to be.
I find this topic interesting as my transmission does not seem to shifting the way it should. I would like to drain and refill the trans but first I would like to determine that I have enough oil in it. What would be the best way to make sure it is full of oil?
The trany is full when oil juuussst starts to overflow out of the filler! Balky shifting as described would lead me to check shift fork set-screws for tightness and position (are they properly seated!) first (this can be checked in the car through the side cover)! I would also not overlook checking the set-screws in the shifter housing rod as that can also affect shifting! Other than that, worn or damaged detents and/or bearings would cause the jamming!
when this happend to my 72 my guy who built the tranny put a washer in that would keep it from going so far forward.
steve
Washers, shims "or" spacers are what ends up happening to take up the end float after the parts that are bad are replaced.
Checking wear on the detents that place the shift forks into set positions, detents and springs in the slider assemblies and the shift fork clearances are all part of rebuilding process.
Washers, shims and spacers can also be apart of shoddy repair if worn parts that are borderline bad, are again reused. So washers, shims and spacers have duel usage. I've seen allot of interesting stuff over the years,talked with some "mature" mechanics that worked on these gearboxes at dealerships and some of the "tricks". Funny stuff....
mine gets stuck in neutral, im thinking it has something
to do with those bearings and stuff that lock it in gear
not releasing when im ready to shift...ideas...z
If you still have the1275 engine I have a spare trans I would like to get rid of. It shifts well and never had problems when it was in the car.
Jim
jim, not sure about everyone else
but ive rebuilt my trans once
already, it shifted fine before
i rebuilt it so i think i can
maybe get it working right
eventually......thx.......z
Zimmy,
Your gearbox has been "fettled" with and it shifted fine before? and it's out of the car now? Then I'd re-look at the detents and springs of the selector rods. The Clymer sprite & midget 1958-1979 shop manual with the blue 74'on the cover shows (real pictures) the placement of all the detents and springs very well. If you have this book re-visit it and if not I might be able to copy and pdf the pages to you.
Hey, you list Love/Hate on your web page! That was a good band for their short time!
"Dug"
figures! i have the haynes!
i also have the complete
official 1275cc sprite-midget 1967-74
on CD....
could i get a copy of the pages u have?
and also...love/hate isnt gone!
they just did a few shows........
check out Crooked X...14 yr olds!
superfragilistic ........zimmmmy
Please include me on the pages as well. Thanks
