Justin Bowen
Member
Just like the subject says... I got a 73 Midget from my Grandma. It's been sitting for 10 years. The original idea was to put a different motor in it (4age, 12a, something like that), but I've decided I'd like to get it running with the original motor before I do anything like that.
So far I've not done much... the car rolls, transmission shifts into all gears, brake and clutch pedal have good pressure.
Last night I took the spark plugs out and dropped some oil in each of the cylinders. I then cranked the motor over 5-10 times by hand. I was happy to see it wasn't seized and it felt nice when I was spinning it. That's all I've done, aside from removing the air pump and all associated hoses. After I replace the dry-rotted hoses under the hood and change the oil and coolant I won't be far from putting a battery in it, crossing my fingers, and trying to start it.
My main concern is the gas. There is gas in the tank. What should I do about this? Would it be sufficient to just siphon it all out and fill it with new gas, or should I consider removing the tank to clean it or replace it?
Sorry if I'm rambling, but this my first post so that's probably expected. Thanks for any info or advice you can give me on my project.
Justin
Justin
