Deleted member 10271
Hi guys,
First, thanks for the help in advance.
I'm a new MG owner, and it's a really cool little '72 Midget. I bought it from an older guy who took pretty good care of it, although he wasn't the original owner.
So, the first issue I notice is that the brakes are soft. I've driven it around town and down my very steep driveway and the brakes have worked, but I'm not very confident in them at all.
I bought some little easy-bleed screws, got them installed, and when I went to bleed the brakes no fluid comes out. The master cylinder was empty when I first started this project, so I filled it up before trying the bleeding. Anyway, I pump the brakes and no fluid comes out. The bleed screws were loosened and so on, and nothing. So then I pulled off the drums and had my roommate pump the brakes and the shoes aren't expanding or anything. Nothing is happening. It's almost like the rear brakes aren't working at ALL. I inspected the brake lines and they look fine, not crushed or anything. I do have some experience with cars...built a '55 chevy years ago but mostly only did the engine work, hence my lack of brake-work skills. One thing I did notice that I was a little confused about was that the shoes and everything inside the drums was really greasy. Are they supposed to be all lubricated like that? Even the shoes? I always thought it was supposed to be oil-free and dry, but what do I know?
Can anyone help?
Can anyone help?
