TR6 71 tr6 exhaust manifold options
skagroovy
Member
I can buy a 6 into one manifold on almost every parts site but they all say 72-76 i can't see any reason why they won't fit ... I am doing a custom exhaust from the manifold back.... If i get a 72-76 manifold will it fit ....please help....
Can't help with your question, but welcome to the forum!
It won't fit the stock system as the 72 on has a dual pipe all the way back.
But since you are doing a custom, dis regard!
the exhaust port spacing are all the same on 71 to 76 heads its the intake manifold spacing that is different, the actual exhaust manifold is different, single exhaust VS dual but again the spacing on the head is the same so if you are making a custom exhaust shouldnt be an issue, but do your research to be 100 percent accurate
Hondo
my 72 has a split manifold, stock, my understanding is the exhaust manifold is the same on all models other than the dual being only on 72. i went thru several ansa systems, rusted out, before going with a stainless falcon dual system. i've been quite happy with it, nice sound and holding up well
