hondo402000
I installed a new wiring harness in my 71 TR6 and I was wondering, when you turn the Ignition switch on are both those 2 red sockets lamps in between the spedo and tach suppose to light up and then go off when the car is running?
since before installing my new harness the hazards didnt work and neither of the 2 red sockets lamps were wired up nor did the oil pressure light in the gauge work.
now after the rewire every thing works, when I turn the Ign switch to on, the left red socket light comes on dimly( and I understand that is is suppose to be dim) and the oil pressure warning lamp in the gauge works and when I start the car both go off when the oil pressure comes up, However I cannot remember if I ever saw the brake warning lamp come on.(that would be the large red lamp on the right.
I have dan masters book and its not really clear on weather both come on or you have to do some re-wiring to get both of those big red lights to light up when you turn the ignition switch to on position.
it could be the PDWA lamp came out of the socket and not grounding
thanks
Hondo
thanks
Hondo
Hi Guest!
