'69 dash parts needed
  • Thread starter Thread starter Mike_Bouse
  • Start date Start date
M
Mike_Bouse
Spitfire 1969 Federal dash. Original gauges. I need the following:
1. Right hand cubby box. I found one (new) for a '71. Would it be the same?
2. Replacement glass for speedo & tach. Also new rubber gaskets for both. Vicky Brit sells these items up to '68, but not later. What gives?
3. The wiper switch/washer pump is shot. What is the best replacement?
Boy, isn't restoration work fun?
DASH/GAUGE O-RING PRICE LIST
May 2004
These O-rings can be used to refurbish standard Smith/Jaeger gauges as found in British classic cars. Sizes shown are the gauge body behind the bezel. Standard, Original, and Durable sets are only different in the dash-to-gauge O-rings. Determine if your gauge has metal ring under the glass in which case it needs three rings (Jaeger style).
Standard rings have a round cross-sectioned rubber O-ring for the dash-to-gauge. This set is suitable for dashes that do not have the gauges "proud" and just require damping. Also used where the gauges are recessed such as on 77-80 MGBs, or when using wood overlays.
Original rings have the square sectioned dash-to-gauge O-rings made in rubber, as were the originals. Suitable for concours cars.
Durable rings have rectangular cross-sectioned polyurethane dash-to-gauge O-rings for durability and high finish. They are also suitable for concours as they are rectangular sectioned with a high finish.
There were some variations (more common with Jaeger gauges) in the bezel sizes so check that your bezel-to-glass ring (the thickest one) fits in the chrome bezel. If it does not clamp down correctly another size may be required. Larger Jaeger gauges usually have a third O-ring between the dial and glass which is difficult to spot. To see if your gauge has a third O-ring make sure you get the glass out completely (and carefully) from the gauge. The paper washers as used in some gauges are not included.
Postage is included - except for orders below $10 for which add $2. Round up order to nearest dollar.
Payment by cash or money order. The preferred method is to enclose dollar notes in writing paper and mail just as a letter. Do not forget to put your address with the order! Inquire for other sizes – but refer to size and make of gauge and NOT to car model.
Some differences exist between certain models so if you want to be sure send bits of your old rings if you wish.
STANDARD
US Cdn ORIGINAL
US Cdn DURABLE
US Cdn
52mm Smith or Jaeger
Gauge-to-dash
Glass-to-bezel
Complete 2 piece Dash & Bezel kit
$1.00
$2.00
$3.00
$1.50
$2.50
$4.00
$2.00
$2.00
$4.00
$2.50
$2.50
$5.00
$2.00
$2.00
$4.00
$2.50
$2.50
$5.00
80mm Smith or Jaeger
Gauge-to-dash
Glass-to-bezel
$1.50
$2.50
$4.00
$2.00
$3.00
$5.00
$3.00
$2.50
$5.50
$5.00
$3.00
$8.00
$3.00
$2.50
$5.50
$5.00
$3.00
$8.00
100mm Smith
Gauge-to-dash
Glass-to-bezel
$2.00
$3.00
$5.00
$2.50
$3.50
$6.00
$3.00
$3.00
$6.00
$4.00
$4.00
$8.00
$3.00
$3.00
$6.00
$4.00
$4.00
$8.00
100mm Jaeger
Gauge-to-dash
Glass-to-bezel
Inner dial
Complete 3 piece Dash & Bezel kit
$2.00
$3.00
$3.00
$8.00
$2.50
$3.50
$3.50
$9.50
$3.00
$3.00
$3.00
$9.00
$3.50
$4.00
$3.50
$11.00
$3.00
$3.00
$3.00
$9.00
$3.50
$4.00
$3.50
$11.00
120mm Smith or Jaeger Dash only
$5.00
$7.00
$5.00
$7.00
$5.00
$7.00
RETAINER WASHERS FOR DZUS FASTENERS as used on the MGB battery box cover PRICE US$3 for six Includes postage
For further information contact; Barrie Robinson, 172 Taylor Drive, Barrie, Ontario. Canada, L4N 8L1
Tel (705) 721-9060 Email barrie@look.ca
I think i was just handed some of the best information i guy coulda asked for!!
Thanks ever so much.
Mike I have it in a better format,if you PM me your email address Ill send it to you.
