Went through the search results and read a lot about these horns, but still have a couple of questions.
The horn will work when pushed really hard or I push the steering wheel at the same time.
Checked the brush continuity ok and the tab to side contact when button pressed.
I took out the signal and headlamp switches but couldn't see anything suspect or much of anything at all.
I noticed the side contact is only connected on one end, is this correct?
I'm not sure where to start checking for a pinched or broken wire,is there some other ground jumper or feed path I should be checking?
Thanks
JD
Thanks
JD
