I am having an issue with the starter on my 67 Sprite. The starting gear does not pull in to the flywheel. The motor spins freely but the gear does not ingage. I pulled it out over the weekend and it seemed a little sticky so we cleaned it up and put a little spray lub on it. It seemed to work a lot better after that. I reinstalled the strater and it worked took the car out for a drive turned it off and the gear would not ingage again. Any ideas would be great
