66 Sprite
  • Thread starter Thread starter xsteamer
  • Start date Start date
X
xsteamer
A friend of mine has a 66 Sprite that has intermittent electrical problems. The tach, gas gauge and tail lights work sometimes and sometimes they don't. I suggested looking at a schematic and finding a common ground or other common point that could be causing the problem. Any suggestions would be appreciated.
I am with you on checking the ground, and also check that fuses have a good clean contact.
You might post this question in the BCF's Spridgets forum too... there are probably more owners/interested parties there regularly than here....
Steamer, check the connections at the fuse block, particularly the one with the 3 green wires coming out.
By all means ask this on the Spridget board as well. That's where most of us "Little Healey" guys hang out.
Jeff
