The rear bearing is a press fit onto the main shaft. A block of wood and a hammer on the rear extensoin is how i remove it. You did remove shift tower and the interlock part under the 6 bolts under the tin cover right? After thats removed the shift fork in there can drop out of the way. If you did not do that the shift forks would probably try to pull all the gears rearward when you try to remove the extension. ????? bob
