Pulled the motor on the '66-B this weekend. The ring gear on the flywheel is toast. The housing on the starter is also very loose. Is this normal?
Cheapest starter I could find was Carquest at $129. Is there another starter option? Seemed to work alright until you tried starting in a spot where there were no teeth. It's all going to be replaced since it's out of the car.
Also, how hard is it to replace just the ring gear on the flywheel? I'm assuming lots of heat and press on....
Thanks,
chris
Thanks,
chris
