Original 1966 mgb with only 49k miles. Just underwent a strip down and repaint with Bright Blue metallic urethane. Engine is original and has GB plate attached. Trans is also original. Many pictures of all the work done. Miles are original as I know the previous owner. He made a mistake on the title and put 58k on it. Car sat outside down south for a long time. Only issue is the floor pans. Steel was cut and riveted over originals(nicely done no oil canning). It will also need a new turn signal switch. Does work, but the cancel feature does not. You manually have to move the lever back. Heat works, wipers work, radio works but cd player does not. Trunk is solid and no body rot. Frame is excellent. Front end was disassembled and blasted and painted. Original Lockheed brake and clutch master cylinders rebuilt. New parts to include: engine reseal, new water pump, a-arm bushings, new brakes all around except the rear drums, new knock-offs, bumpers, overriders,headlight bezels,tail light bezels and lenses, emblems, grill,clutch lines,rubber brake lines, driveshaft u-joints, rearend rebound straps,rack and pinion boots,halogen headlights,tires, elec.fuel pump, door weatherstripping, etc..Trans was disassembled and new 2nd gear syncro installed. This is a 3 syncro model w/no overdrive. Original windshield that shows some fogging near bottom. Passenger door glass is original Triplex. Original Smith gauges work great. Car is negative ground with updated alternator. I also installed a new ministarter. Seats recovered in black vinyl with blue piping. New carpet kit. Comes with spare wire wheel. No jack kit. Does not have a soft top, but I have the bow kit. An optional Parish Plastic removeable hardtop comes with the car. No trades. Great driver and shows well. Any questions please ask, Chris 330-204-4199. My ebay ID is clehman454 to check feedback. Asking $7900. All receipts. Email me directly for inquiries. c_lehman67@hotmail.com
1966 mgb 49k original miles
