John Kuzman
Does anyone know if the driveshaft splined slip yoke used in the "Smitty" conversion is a specialty item or an off-the-shelf item? If off-the-shelf, what specific application? Thanks.
Hi Guest!
I think the original Smitty 5-Speed instructions had Driveshaft instruction details if anyone still has a copy, maybe they can post them?The Toyota splined yokes are widely available aftermarket; the Healey joints are standard sized. The Toyota yokes are a standard size which fits all the W-series trannies.
You measure the distance between the flange on the back of the trans and the flange on the front of the diff. The driveshaft maker will know how long to make the driveshaft.
Take your Healey driveshaft so they will be able to see the specs of the U-joint at the rear.
Steve -
Thank you very much for the attachment. It shows the yoke as "Toyota 1-2303-21". That is what I needed. My problem is that the yoke on the driveshaft supplied with the 5 speed kit will not slide far enough in to the transmission. It slides in about 2.25" then hits a solid, metal on metal stop. It is not on far enough to bolt the rear flange.
The transmission was supposedly re-built by a professional. I just want to try a different yoke before I once again go through the pain of pulling another transmission.
For my earlier problems, see: https://www.britishcarforum.com/bcf/showthread.php?110884-5-Speed-Issue&highlight=kuzman
Gee, one of these days I may actually get to drive my BJ7 with a 5 speed!
Steve -
Unfortunately, it’s normal.Been calling and emailing for over a week. No response.
