5/16 or 3/16 line for fuel?
msoylemez
what's original on the bugeyes? I believe it's 3/16.
Is it alright if I run 5/16 line?
I'm running SU H2s, and a napa universal pump with 2-4psi pressure.
thanks.
I don't know what the size is on the Sprites, but I seriously doubt the the fuel line on ANY car is 3/16". The ones I've always seen have been either 5/16" or 3/8"...I would imagine there might be some 1/4" fuel lines out there.
""""Is it alright if I run 5/16 line?"""""""
Better check with Fuel-land Security on all liquids. Seriouly tho.....either 1/4" or 5/16' will be fine unless your pumping the big HP numbers.
BUT....the carburetors want to see a max of 3psi. Use the small inexpensive adjustable 2 to 5 psi Holley regulator.
pretty sure it's 1/4" on my spridget for the hardlines. I run 5/16" on all my soft lines.
You don't need an upgrade to 5/16 or 3/8 all the way through for a little a series block, but it's not going to hurt...
The original was 1/4". As long as you are not racing the 1/4" stuff works great. Keep it simple. I do run all 5/16th on my cars.
