Tinkerman
I am rebuilding a TR4A syncro box for my TR3. I was humming right along with the reassembly and ran into a snag. I installed the the bearing onto the input shaft or as they say in the manual, the "constant pinion shaft". Next was the bearing washer item M39, part number 60078. Am using the same one that came off the input shaft. Went to put the snap ring(new) on and there is not enough space for it. My question is did I not get that bearing seated well enough. The bearing is actually smaller in width by about .003 and the washer is right on with Nelson Riedel's measurments in his article. I did not use a shop press to put the bearing on the shaft. I used a large hammer and a metal tube of the right size.
My feeling is that there is some small amount of space left to go and the hammer and tube routine cannot get it, therefore I shold finish it with a shop press.
Any thoughts greatly appreciated.
Tinkerman
Tinkerman
