TR4/4A 4A door windows
HarryL
I have the windows out of the car and am ready to place them in.
Have the inner seals in place & was wondering if I put the outer seals in place
can I slide the glass thru these guys ?
Harry
Harry-
Not positive, but I think it will be easier to leave the outer wiper seal off to get the window in. Also, drop the window all the way down which will make it easier to get the outer seal in place. I'm in the middle of replacing one that is rotten, I'm not pulling the window but it is difficult to work with the seal unless the window is lower than it is normally.
Randy
You will need to put the windows in first, then the outer seal. I made a clip holding tool out of an old cheap flat tip screwdriver. Its still a bi#$* to get them in place.
Marv
