Hi All. I have the chance of a 4 speed overdrive box. Is it worth fitting and do I have to make any chances to my car to do this. I have a MGB MK2 the box is from a MK2. Do I need any other parts as it comes as just the box. Is the clutch and slave clyinder the same. Is the wiring there for overdrive or do I have to fit a wiring loom. As you can see I am not sure what is involved. Does the box fit on the engine without any modifications. Thank you for your help. Regards John.
Hi Guest!
