I backed the 230 out for a wash and ride on July 4. When I tried to start it again it would not start. I changed plugs and condenser and set the points with a dwell meter.(Could not find points locally).
The car started but idles rough, very rough. I cracked the connector connections at the cylinder and got a lot of air bubbles from the line on #5 & #6. The others had little if any air bubbles. Any one have any idea where the air is coming from since the system is pressurized all the way from the tank?
It seems that if there were a leak out side the tank there would gas leaking out. HELP.
Thanks, Pete
Thanks, Pete
